  1. Member Klagar's Avatar
    Sep 2010
    Montreal, Canada
    Hi !
    I'm desperate and I don't want to search for hours once again...
    Can anyone tell me where I could find the file "presets.xml" which WinFF uses as a reference to load its presets, in Windows 7 ? It took me some time to find it in XP, it was in the Application Data folder, and I thought I could find the same file in the AppData folder of W7, but it seems Windows doesn't use the same logic as I do.
    Thank you !
  2. Member Klagar's Avatar
    Sep 2010
    Montreal, Canada
    I found what I was looking for !
    Unless someone wants to answer for future reference, I just had some bizarre setting and thus tried something crazy and got what I was looking for.
    Thanks anyways ! :P
