Hi everyone !
Now I just came across the -partitions parameter in FFMPEG. I shall eventually test its effects on encoding, but I thought maybe someone could impart some quick insight as of how it influences the quality of the product ?
I saw there are (so far) five possible values to this parameter : parti4x4, parti8x8, partp4x4, partp8x8 and partb8x8. I think I understand basically how it influences the way macroblocks are considered, but what I'm interested in is whether some of these flags are made to respond to precise standards, which ones are better suited for quality, which ones are better suited for speed, and which ones should produce the lightest/most heavy files ?
Thank you for any advice that can be spared !![]()
Results 1 to 1 of 1
Do partitions on HDD slow down performance ?
By Noahtuck in forum ComputerReplies: 20Last Post: 19th May 2014, 10:33 -
HDD Partitions question.
By SE14man in forum Newbie / General discussionsReplies: 13Last Post: 24th May 2011, 14:32 -
partitions
By jyeh74 in forum ComputerReplies: 11Last Post: 1st Jul 2009, 22:33 -
Best way to partion a 1TB into 2 partitions using Fat32
By cal_tony in forum ComputerReplies: 6Last Post: 21st May 2009, 12:10 -
Join two partitions
By Jomapil in forum ComputerReplies: 5Last Post: 11th May 2009, 16:28
