Is it possible using LP Recorder to access audio files already on my hard drive in order to trim and edit them?
hi, are you talking about this?Is it possible using LP Recorder to access audio files already on my hard drive in order to trim and edit them?
http://www.cfbsoftware.com/lprecorder/lprecorder.aspx
take a look at Audacity to record,edit, your LP's , it has more features and yes you can access the audio files already on your hard drive for trimming & editing.
you can even add VST Plug-Ins to process your recordings (eq,reverb,compression,etc.. etc)
Trimming with Avisynth: An exploration
By Krelmaneck in forum EditingReplies: 2Last Post: 22nd Oct 2010, 12:20 -
Trimming with AVIDemux
By BobAchgill in forum EditingReplies: 10Last Post: 12th May 2010, 23:05 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 02:06 -
lossless editing MPEG-2 (*.mpg) with trimming and appending with preview?
By Andy Gone in forum EditingReplies: 8Last Post: 3rd Sep 2008, 06:49 -
AVI - Lossless Trimming
By tripecac in forum EditingReplies: 14Last Post: 4th Jul 2008, 02:03
