I am trying to make a VCD. The movie is all set-up and ready to go, but in the start of the VCD, I want to add a little file, but after I finished converting it to 50MB (the size I have left on CD), it was not accpepted by Easy CD Creator 5. Is there a way to fix this, or should I try another program to burn like NERO?
Sorry if this topic is in the wrong forum, but I think I might have to convert more...
Use TMPGenc, select your little movie, hit load and select the VCD template (PAL or NTSC) > convert.
This will make a fully compliant mepg and Easy Cd creator will not complain. -
I tried what you two said, but I think there is only one problem, the BITRATE. I have set it to about 2500 BECAUSE I want the file to be 50MB, but if I put it as STANDARD VCD, the size will be less, meaning the quality will be less.
Sorry, I found my mistake. I found out that the bitrate has to be MAXIMUM 1152kbps. Thanks anyways.
