Results 1 to 12 of 12
  1. Hi all,
    I've been using Fairuse to rip dvd's to avi, it has worked fine until now, but now something is wrong. It keeps saying "muxing error" when it comes to merge mp3/avi w. vdubmod.
    I tried to download VirtualDubMod_1_5_10_2_b2542, full package, when I run the VirtualDubMod.exe nothing happens at all, it shows up in task manager, but thats all? Its driving me crazy, i tried many version, none of them starts up, it just stays in the task manager.. hrrm
    Anyone that has a good idea how i can get it to work? ps: im using win7 x64
  2. Originally Posted by CreazioN View Post
    Hi all,
    it's quite strange coz i hv been using VirtualDubMod_1_5_10_2_b2542 until i switched my Os and i was very happy with it.
    try to get it from HERE
  3. Can you provide the links for the files you want me to download, so we're 100% sure ill try the right files. I really don't understand why it does'nt work at all
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Are you sure you've downloaded the whole package? If the archive contains only the main .exe and one or two other files, it's the 'upgrade' version.
    If you've downloaded the 'full' version, make sure you extract everything with the full folder structure intact. VirtualDubMod insists on a number of components being present, in certain locations.
    Last edited by Ai Haibara; 5th Oct 2010 at 07:25. Reason: omitted an important word... bleah.
  5. Originally Posted by Ai Haibara View Post
    Im sure I have the full package, if you provide me a link to the full package that would work with win7 x64 i'd love to make some screendumps of everything i tried until now.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    I'm using the version available from VideoHelp's Tools page for VirtualDubMod under Vista x64, with no problems. It should theoretically work on Win7 x64, but, of course, I can't make any guarantees. Where are you placing it? You're not setting it up as a folder within any of the Program Files directories, or the desktop, are you?
  7. Originally Posted by Ai Haibara View Post
    I tried it located in fairuse folder, in the programs, tried in the root of drive C/D - tried from desktop.. hrmm..
    I'll try later the package you're talking about, im at work right now.
  8. I have three versions of VirtualDubMod (1.5.4.1, 1.5.10.1, 1.5.10.2) and all of them run fine from Windows 7 Ultimate 64 bit. They are all located on a mapped network share, G:\Program files\VirtualDubMod... No special settings. Ie, they are not running in XP compatibility mode, or "XP Mode" emulation.
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Does that include the version installed with AutoGK? :P
    CreazioN: If it's worked until recently, have you installed any new 32-bit codecs/DirectShow filters or video-related programs?
    Just to be sure, you might also download the current version of VirtualDub (the 32-bit version) and see if that has similar problems.
  10. I just downloaded VirtualDubMod from the direct link here at VideoHelp
    https://www.videohelp.com/download/VirtualDubMod_1_5_10_2_b2542.zip
    extracted the folder to the Desktop and ran the program. It worked fine.
    I would try deleting the registry entries:
    HKEY_CURRENT_USER\Software\Freeware\VirtualDubMod
    HKEY_CURRENT_USER\Software\VirtualDub.org
  11. Finally home, the folder in the vid is the zip content from https://www.videohelp.com/download/VirtualDubMod_1_5_10_2_b2542.zip - Let me know if there is anything you need to know, or having an idea that might help me out
    vid: http://www.youtube.com/watch?v=ACl970v6fu4
  12. i can see that i forgot to close another proccess with that name, its the same shit :/
