I have just started working with a surgical company that produces videos of operations. They have been hiring outside vendors to film and edit these videos in the past and they would like to now do the editing within the company. While I have experience editing with premiere, I don't have experience with setting up the specs needed for the computers to run premiere (i.e. hardware, specs, system requirments, etc...). I would appreciate any and all suggestions on what you feel the company would need to purchase to set up a video editing station.
Please help.
Thanks,
A newbie to setup
Shawn, when you say "build" do you mean assemble all components (case, power supply, mobo, etc.) yourself or specify the build for, say, Dell?
The Adobe website, as well as sellers of Premiere, list both minimum and recommended system requirements to run the software. Always follow the recommendations for maximum performance. You will always need a dedicated harddrive for your video project files. Graphics card, CPU power, etc. will depend largely on whether you are editing SD or HD footage. In the case of HD, if your footage is AVCHD, then you will need a powerful system. Conversely, HDV is a bit less demanding of the system.
editing a dvd or bluray in Adobe Premiere Pro CS5.5
By caretaker1379 in forum DVD RippingReplies: 5Last Post: 16th Mar 2012, 16:44 -
Adobe Premiere Pro CS5 Editing Effects?
By Napy666 in forum EditingReplies: 1Last Post: 20th Aug 2010, 18:43 -
Adobe Premiere Pro - video proxy tutorial???
By rallymax in forum EditingReplies: 5Last Post: 28th Aug 2009, 00:46 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 14:16 -
Editing and exporting already compressed video in Adobe Premiere
By Rocky88 in forum EditingReplies: 4Last Post: 31st Jul 2007, 08:52
