Results 1 to 11 of 11
  1. Hello. The TV I have is a GRUNDIG LCD (Model GU19WDV4). I have a Sony DVD Player (DVP-NS305). I'm using S-Video/Stereo Audio Cable to watch DVDs. The sound & picture looks good, but the movies are shown in black and white. It used to be a color picture but suddenly went black and white. I tried a new cable and new DVD player without luck. How do I fix it? If anyone can help me out I'd really appreciate it.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What country do you live in?
    What country is the DVD you are watching from?
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I've seen NTSC discs play in black and white on a PAL tv in the past. Can you confirm a match in tv standards for the disc/player/tv ?
  4. Hi hech54,
    I'm based in UK and all DVDs I tried to watch were bought at HMV.
    I used to get a colour picture but suddenly went black and white.
    Thanks in advance for your help
  5. Hi Case,
    How do I check that:
    'Can you confirm a match in tv standards for the disc/player/tv ?'
    Sorry for a stupid question and thanks for your help
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by majstrydwa View Post
    Hi hech54,
    On the same DVDs? (DVD was color yesterday - same DVD is black and white today)
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Hi hech54,
    I just went to HMV's wesbite and did a search for "NTSC":
    http://hmv.com/hmvweb/simpleMultiSearch.do?searchUID=&pGroupID=-1&adultFlag=false&prim...mitSearch.y=15
    You probably bought NTSC DVDs from HMV....so you need to change the settings on your DVD player.
    Hopefully your player is capable of doing that.
    NTSC - North America
    PAL - UK, Australia and the rest of the world.
  8. You could always find an old black and white television for it.
  9. Member classfour's Avatar
    The Heartland, United States
    Change the cable from the player to the tv
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  10. I would say the s video connector on your tv is defective, probably just needs to be re-soldered. If anything just use a composite video cable instead, doesn't make that much difference.
    Nov 2000
    Canada
    Busted cable or connector. Concur. If it's the cable, the dollar stores in your area must still sell cheap ones. They do here...
