Hi,
I was just wondering if you can get a ' WAN (Wireless USB connector)' or Card for your PC. Obviously you can get those but i was wondering if you can get one which has an extra extra strong signal sniffing strength which can sniff out wifi spots far away?
Thank you!
Mart.
	To do this you would need to connect an external antenna to the wifi card/dongle. There are antenna that have parabolic collectors on them that may pick up fainter signals. You can also make them yourself, with many designs available online :
 http://www.freeantennas.com/projects/template/
 http://www.instructables.com/id/Uni-Directional-WIFI-Range-Extender/Read my blog here.
	While we're on the subject, do u have any idea how to gain access on a wireless for a Pre Shared WPA key?
 Cheers.
  What usb wireless N adapter to get?By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 09:49
  Is There Such A Thing??? re: Pinnacle Studio 500 USBBy drtalk in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2010, 20:21
  DVD player with way to update DivX codec or usb to watch vids from? Exists?By spycam in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Oct 2007, 22:05
  How does the USB connector work?By maxxDV in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Sep 2007, 12:29
  USB Wireless lan stronger than Internal wireless?By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
