Is there any simple way to do it?
I don't care if it doubles the framerate or not, I just want a video that looks good and sharp - I really hate the vertical bars showing in moving scenes, it's distracting while watching and produces bad screenshots.
Also, both VirtualDub and VirtualDubMod have ceased working, they'll start just fine but upon opening/playing videos they crash. I've just noticed it while trying to open random videos today and dunno what caused it, so they might be out of question to do the conversion.
Thanks in advance!
I think you mean horizontal bars
No, you really can't go from 1080i to 1080p and get really sharp images. The process is called deinterlacing, and it can be done, however in all cases you will get a softer image. You either end up dropping every second line, then resizing up, or trying to average the interlaced areas. You will not get an interlaced video to look like a truly progressive video. Some can do a decent job, but they take a lot of time to run and means re-encoding your video. You also need to use avisynth to use the best deinterlacers, and unless you want to re-encode to an AVI container, virtualdub is very much the wrong tool to be using.
You could try using a better player that deinterlaces on the fly. At least then you aren't doing permanent damage to your files and aren't waiting for many hours for them to be processed.Read my blog here.
1080i to 1080p
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jan 2011, 06:38 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 10:57 -
1080I camcorder or a 1080P
By zapper130 in forum Newbie / General discussionsReplies: 9Last Post: 16th Jan 2009, 17:44 -
1080i vs. 1080p
By Shibblet in forum DVB / IPTVReplies: 31Last Post: 27th Sep 2008, 14:24
