I bought the ADVC Canopus 110 converter and hooked it up. I tested it with both Windows Movie Maker and Nero Start Smart. Both capture the material, however, when I play the clip back, I get no sound. I understand that when I'm converting there is no sound, but shouldn't I get audio on the playback? I double checked my connections, I have monster cables and they are hooked up. What should I check for?
First check the file with MediaInfo and make sure there is really no audio. A player may just not recognize the audio format, though it should be PCM. You could also try a different program for the DV transfer. WinDV is popular around here and very simple to use.
There are also two different configurations of DV, DV-1 and DV-2. The difference is how the audio is combined with the video. Not all programs accept both configurations.
Canopus ADVC-110 Studio 10 Audio problem
By jimlong in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2010, 20:12 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 13:29 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 15:15 -
ADVC-110 Brightness and TBC problems
By harmlessgryphon in forum Capturing and VCRReplies: 14Last Post: 5th Jul 2008, 13:55 -
Will the Canopus ADVC 110 converter work for my Sony DCR-DVD92?
By briandk17 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 05:54
