  1. Hi . . .
    I have a Pioneer 20X DVD±R DVD Burner Black SATA Model DVR-216DBK http://www.newegg.com/Product/Product.aspx?Item=N82E16827129032 and burn .avi files onto disks. I've been burning onto 4.5Gb disks but some of the files are too large to burn to 1 DVD. Is there a larger disk that I can buy to contain a movie that's about 1.5 Gb? I've found some larger disks on the internet that are dual layer but I don't know what that means or if my dvd drive can burn to a dual layer disk. I have Windows X64 and I use Nero to burn to disks. Can someone help me out?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Yes it can - look at the last line of the write speed on the spec page you posted:
    WRITE Speed DVD+R20X DVD+RW8X DVD-R20X DVD-RW6X CD-R40X CD-RW32X DVD+R DL12X DVD-R DL12XYou can burn dl discs with this drive.
    Dual layer discs are 8gb.
    Dec 2004
    Atlanta, GA
    According to the specs shown on the page that you link to, your burner will burn DVD-DL at 12x. A few words of advice. Buy Verbatim Double Layer discs. Any other brands will be a total waste of money. Download Imgburn from the tools list at the left of your screen. It is free. Use it, not Nero, to burn your DL disks.
    Matt
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Well, personally I wouldn't use Nero for much of anything, especially DL discs. ImgBurn does a much better job. I would also stick with Verbatim DL + discs are they are the most dependable. I still use the 2.4X speed discs and I have done a hundred or so burns with no failures with ImgBurn and VB + discs on several different burners. Most of them are MKV (data) burns.
    The 216 should handle DL discs with no problems. If you can't find Verbatim DL discs locally, NewEgg, Rima, SuperMediaStore and others all carry them.
    And this isn't Video Streaming. Moving you to DVD & Blu-ray Writers Forum.
  5. Ok, thanks a bunch everybody
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Seriously ??
    WRITE Speed
    DVD+R 20X
    DVD+RW 8X
    DVD-R 20X
    DVD-RW 6X
    CD-R 40X
    CD-RW 32X
    DVD+R DL 12X
    DVD-R DL 12X
    If it was a rattlesnake, you would have been bitten
  7. LOL . . . I didn't know what DL meant but I do now !!
  8. Member ricoman's Avatar
    Jun 2004
    CT, USA
    Since you seem new to this, if you want to burn to DL disc, only use Verbatim DL discs. IMHO (and many other people's), Verbs are the only reliable DL media. Also, for regular disc, JVC (TY) and Verbs, don't bother with others, they are iffy at best and terrible often.
    I love children, girl children... about 16-40
    W.C. Fields
