I have some (rmvb,mkv) video files and i'd like to know how to remove a certain scenes from them and save the new files without this scenes .any help???
You may find that very difficult with RMVB as it's a highly proprietary format and not that many editors are available. I would convert it to something easier to edit. MKV varies, depending on the codecs used. Both formats share one major editing problem. They are very highly compressed and even for simple cuts and pastes you would have to cut on a keyframe to limit sync problems and video distortion. Otherwise you would likely have to re-encode the file. Key frames are generally widely spaced with these type of formats, so frame accurate editing is very difficult without re-encoding.
If I had to do frame accurate edits, I would convert the files to a lossless codec like HuffyUV or Lagarith and edit in that, then re-encode to the preferred format. I've used Any Video Converter for the conversions as it can usually handle RMVB. MKV is a bit more complex as that's just the container name, not what formats/codecs the file is using. If it's H.264 and AAC audio, not so easy to edit either.
But others here may have better advice.
thanks for your help but could you tell me what is the best way to convert rmvb&mkv to Avi and then remove the scene from the avi file??
Getting exact pixel and display width in an mkv using Handbrake
By skinney6 in forum Video ConversionReplies: 6Last Post: 12th Mar 2012, 12:46 -
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 17th Jan 2011, 00:05 -
Which software is good at delete scene of a MKV movie without re-encoding ?
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 7th Jan 2010, 06:37 -
RMVB to other formats.
By POCHINI0 in forum MacReplies: 2Last Post: 13th Nov 2009, 21:32 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 22:09
