After using Soopafresh's Avi Gain for 3 years I have a problem. Recently upgraded system to Win 7 64bit
and find Avi Gain won't work. I have tried administrator mode, XP Sp3 compatability mode etc.When I load
avi. files and double click Bat file the Command line box flashes on screen and then absolutely nothing
happens.Any suggestions please?
Maybe try updating the included executable's...I'm fairly sure all of them are outdated.
Start a CLI and manually run the batch file. Any difference? Add a pause after each line to see where the batch file fails.
I just downloaded the version from here:
https://forum.videohelp.com/threads/255147-Mini-Guide-Normalizing-Audio-for-Multiple-AV...light=avi_gain
and ran the "regular" batch file in Win7 64 bit and it worked just fine. Three videos in the same folder (some with spaces in the name, some without) were normalized. Maybe your AVI file isn't really an AVI file?Last edited by jagabo; 5th Nov 2010 at 06:40.
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 17:44 -
Lame MP3 on Virtualdub 64bit (win7 64bit)
By EdoScario90 in forum AudioReplies: 5Last Post: 2nd Sep 2012, 11:30 -
I can't change AVC codec to ffdshow under win7(64bit)
By skinney6 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2012, 12:08 -
I can't get multiAVCHD to install running win7 64bit
By Onceler2 in forum Authoring (Blu-ray)Replies: 0Last Post: 17th Sep 2011, 21:29 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 06:39
