Hi all,
Before proceeding, I'll mention that I attached a "MediaInfo" file, if it'll help at all. The report is on the original, full, unconverted movie...
Anyway, I've run into the following problem with both Vegas and Premiere. I did nothing but take a short clip from said film and tried to convert it from ".mpeg" to a format I thought would be even more DVD-compliant. When I play the clip back (now converted to a DVD) in WinDVD, it'll play fine for about 15 seconds, then it begins playing in a choppy manner. I tried to see what would happen when adding chapters and after each one begins it's a similar situation, but the duration is even shorter, at around 5 seconds before playing choppily. However, it plays fine in VirtualDub.
I'm not sure if it has something to do with the file I'm working with, what I'm converting to, what apps are used, etc. I used DVD-lab PRO 2 for the authoring.
I appreciate any help you can provide.
Thanks,
Justin
Results 1 to 24 of 24
Yeah, I noticed when I closed my browser. Brilliant move, ugh.
Dang... what'll it take before I actually get the thing attached?!
Finally. *wow, I'm off to a great start!*Last edited by takearushfan; 1st Oct 2010 at 22:34. Reason: Validating my idiocy...
You can just paste text into your post, use CODE tags to keep formatting:
Code:General Complete name : C:\...\Carnival Of Souls.mpeg Format : MPEG-PS File size : 2.05 GiB Duration : 1h 22mn Overall bit rate : 3 538 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=15 Duration : 1h 22mn Bit rate mode : Constant Bit rate : 3 000 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.290 Stream size : 1.75 GiB (85%) Audio ID : 128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 1h 22mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Video delay : -67ms Stream size : 266 MiB (13%)
It's already DVD compliant. Why'd you reencode it? If whatever authoring app you use wants elementary streams, then just demux it (DGIndex, among other apps). And why'd you use Vegas and Premiere for anything having to do with this thing? I mean, I might want to IVTC it and otherwise filter it to improve the (probably) lousy quality before reencoding it myself, but I wouldn't use those programs. Nor would I ever get within 10 feet of WinDVD. Cut with MPEG2Cut, demux, IVTC and filter via AviSynth if you like, reencode if you like, reauthor with Muxman, and it'll play as did the original MPEG.
(I hear an echo in here.
Hi again,
I don't know what the original file I have might've been through. I found it online, from a Public Domain website. For all I know it's already been converted back and forth and been through hell.
My reason for using Premiere is to attempt some restoration/cleanup. I take it that Vegas and Premiere are lousy at doing such things? ... I mean, why do you frown upon them? ... and WinDVD?
I'm assuming the tools you guys mentioned are some of the best alternatives to what I've been using? -
You said the result played jerky, didn't you? So, somewhere along the line you or the software you used screwed up, didn't it?
Sorry about insulting WinDVD. I was thinking of WinAVI. Anyway, why pay for DVD playing software when there are free ones available? Did you try something else to play the DVD (a real DVD player and not VDub). Or maybe WinAVI was included with your computer or some other software?
One IVTC's in AviSynth. Many people also do their other filtering in AviSynth. -
Well, it must be the software, since VDub played it fine, albeit crappier looking.
The main filters I'd be using would be those for sharpening and noise reduction. Unfortunately, I have no idea how to use AviSynth, as it's script-based and a bit intimidating. Though, I suppose it's worth trying out. -
Thanks. BTW, I hadn't heard of IVTC before and had to look it up. Is its main purpose to improve picture quality? How well does it work?
Film rate is 24p , which isn't compatible with NTSC systems which are 60Hz . So it has to be either flagged/packaged or hard encoded in a way that is 60 fields per second (actually 59.94, we just say 60 for rounding). That is essentially telecine . IVTC = inverse telecine, and is reversing that process and recovering the progressive frames
premiere and vegas are editing software , not restoration software. Not a good choice
I would start from the original source (or as original as you can get) . Since it's public domain , start with that. If you start with a DVD, you are incurring additional generation/compression losses, which is detrimental for any restoration efforts. If you post a sample some people can give you suggestions to clean it up -
Hm. If I post a sample, what would be the ideal format... I'm assuming as-is?
That's right, from the source. One way is to open it in DGIndex, mark off a small section with steady movement using the [ and ] buttons and then go File->Save Project and Demux Video. If the resulting M2V is good enough and small enough, upload it to Sendspace or MediaFire and give us a link.
Okay. Sorry for the delayed reply. Here's the M2V link:
http://www.sendspace.com/file/oltg8l -
It's just standard hard telecine that just needs a standard IVTC, something like TIVTC's TFM().TDecimate. It can also use other cleaning up. Included is the reencoded sample that used the script below, although I'm sure others would do it differently:
TFM()
TDecimate()
Crop(14,4,-8,0)
LanczosResize(704,480)
Tweak(Sat=0,Cont=0.91,Coring=False)
FFT3DFilter(Sigma=1.5,BT=5,BW=32,BH=32,OW=16,OH=16 ,Sharpen=0.4)
AddBorders(8,0,8,0)
ConvertToYUY2()#for CCE -
Hm. Despite my looking up the term, I'm still not too sure what took place here. I see that the frame rate has been restored, which is something I do recall reading, but what else did your IVTC do? It looks like it's now de-interlaced...? (I must frequently remind myself that there are no stupid questions)
Although one effect is to remove the interlacing, it's not been deinterlaced as such. A deinterlacer wasn't used, but a field matcher (TFM) and decimator (TDecimate). They match up the fields and toss out the duplicates. You have to have an understanding of telecine and 3:2 pulldown before knowing what an IVTC (InVerse TeleCine) does:
http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.html
Scroll a little way down to The Nature of Interlaced TV, Film-to-Video Conversion, and Other Interesting Gambits and specifically to the Re-Interleaving 24fps Film part. Reinterleaving is what they call IVTC (better than what most such articles call it, which is deinterlacing). That whole page is worth memorizing.
Or this article which actually has a section called Reverse telecine (a.k.a. inverse telecine (IVTC), reverse pulldown):
http://en.wikipedia.org/wiki/3:2_pulldown#3:2_pulldown
There's a zillion articles on this stuff. All you have to do is look them up. -
Just a quick stop-by to say thank you. I appreciate the info
I'll check it out in a bit
Hm. What plugins were required for this script to run properly? For that matter, can you recommend some plugins that are specifically intended for cleanup? I've noticed that it can be tough to not overdo it when applying certain filters. Apparently, the "less is more" cliche tends to apply rather frequently in this case.
The ones I used in that script also did some cleaning up. Tweak, Crop, the resize, AddBorders and ConvertToYUY2 are included in AviSynth, so no special plugin is required. The 3rd party filters in the script are the IVTC (TIVTC's TFM and TDecimate) and the FFT3DFilter. Both can be found here:
http://avisynth.org/warpenterprises/
Read the doc included with FFT3DFilter for special install instructions. Also, in that 'best' mode it's fairly slow. Read the doc for faster settings if you want them. It's the 3D cleaning filter I used on that one. Or, use different filters:
http://avisynth.org/mediawiki/External_filters -
Thanks. Regarding the speed, I'd rather have it take forever for better quality than to speed it up and sacrifice quality.
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 07:04 -
Choppy Playback - Suggestions?
By icecold0725 in forum Newbie / General discussionsReplies: 21Last Post: 12th Oct 2010, 10:06 -
Choppy video playback
By dexter30 in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 13:10 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 08:40 -
Choppy playback using nero.
By compduce in forum Video ConversionReplies: 5Last Post: 24th Jul 2007, 00:21
