I have a question and a little problem:
The question. How can I make a menu with nero(or any freeware if possible) that will play the selected video clip then return back to the menu.
the problem I am having right now is any menu I create that has multiple mpg clips(using nero 5.5.6.4) has these two problems. First off once one clip is selected it will play that clip and any clip after that(basically the above question). My second problem is that I can't stop and resume my vcd's if they contain menu's, what is the cause of this if known?
Thank
Ryan
Results 1 to 1 of 1
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 10:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 13:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46
