Hi!
I've managed to make a dvd with ifoedit, I managed to change the green colour of the subtitles, add menus with "merge menu table"... but there are still 2 things I can't do. First one:
1. When I merge the menus, they work, but the audio stream of the menus is missing... I don't know where to change the settings so the audio of the menus is audible again...
2. The chapters: I don't know how to change the "cells" to set the start and end frame. I made a CELLTIMES.TXT with the time in frames (for example: 23850 - 47100). And well, it has its divisions, but not where I wanted them.
I would realle apreciate any help! Thanks a lot!!!
IFOEdit takes a celltimes.txt file with the chapter stops in frame numbers. But it won't set them at any old frame numbers, but only on I-Frames, which may be up to about half a second away from where you really want them, unless you want them on a scene change where there's usually a good I-Frame. But what you posted (23850-47100) is the wrong format. It should be:
23850
47100
Why not use a real authoring program that allows for the import of video and audio you've made for menus, ones such as the free ones, DVDAuthorGUI, GUI4DVDAuthor, and DVDStyler? I don't know anything about using IFOEdit for adding in menus. In fact, it's the first time I've ever read of anyone using it for that. -
Manono, thanks for answer!
I use ifoedit because I susually use Adobe Encore CS3, but this time, I can't, because the DVD I'm authoring is from a TS from TV and Encore don't allow me NOT to transcode it, so I use IFOedit so the video is not recoded. But I have the menus made with Encore and I have inserted them in the IFOEDIT, but without sound...
I'll try again what you tell me about the cells!
Thanks a lot!
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
help me with some bluray ripping/authoring questions
By ronorkis in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2008, 21:07 -
2 questions about DVD authoring
By ihmcjacky in forum Authoring (DVD)Replies: 23Last Post: 5th Jul 2008, 05:21 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 23:30 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37
