    Sep 2010
    Trivandrum
    Hello to all,
    I use xvid4psp5 to convert videos and embed subtitles & suddenly the videos are not showing up.i will give a screen shot of it.....
  2. That's an AviSynth error message. It says, "Resize: Source image too small for this resize method. Width=0, Support=4. C:\Templpreview.avs, line 7".
    Something's wrong with line 7 of your script. Did you edit it, or open a script of your own in XviD4PSP? Post the script here if you can't figure out what's wrong.
    If you didn't do anything to cause that, maybe uninstall and reinstall, or install a different version.
    Sep 2010
    Trivandrum
    no friend ,i haven't done anything with the script .i tried uninstalling and reinstalling but it shows the same result.The Script you asked is here........
    import("E:\XviD4PSP5\dlls\AviSynth\functions\AudioFunctions.avs")
    import("E:\XviD4PSP5\dlls\AviSynth\functions\Video Functions.avs")
    DirectShowSource("G:\Software\Diskeeper_Home_Editi on\`\Hindi Songs\Tune Jo Na Kaha.mp4", fps=23.976, convertfps=true)
    ConvertToYV12()
    Lanczos4Resize(16, 16)
  4. Do you really want to resize to 16x16?
    Sep 2010
    Trivandrum
    I don't know . it just appeared in the script .i want to open it in the normal way as every time.
  6. I don't know what's wrong. Try changing the resize to something like :
    Lanczos4Resize(624,352)
    Sep 2010
    Trivandrum
    i installed ffdshow after this happened. now the video is loading in it but i cannot see the video only the audio is coming up.the preview window is in grayish white color.
    the avisynth script is here.......
    ConvertToYV12()
    #Mod16xMod8 protection
    Lanczos4Resize(1280, 536)
    sceenshot.....
