I just imported some RAW DV (.dv) footage onto my Brothers Mac (Only Computer with Fire Wire port)
I then imported the video into my Sony Vegas Pro program on my computer
The Audio works perfectly
But the Video in the time line does not play back
The files are big
For example, an 18 second clip is 65 megs
How do I rectify this
Running Sony Vegas Pro 9.0 (Build 563)
It needs to be DV-AVI (wrapped in AVI container)
You can try mpegstreamclip to re-wrap it (you might need quicktime or quicktime alternative installed) , file=>save as (drop down menu select avi)
or you can use ffmpeg , but it uses command line
e.g.
ffmpeg -i input.dv -vcodec copy -acodec copy output.avi
That filesize is normal for DV -
Hey Poison Death Ray,
Thanks for the quick reply
I was searching through the forums earlier for anyone else who had experienced the same problem as I had.
Turns out its the newest version of Quicktime player that has been causing problems for Sony Vegas and other programs
I uninstalled Quicktime and installed and older version (I think Quicktime 7.5.5)
Now it all works perfectly.
Chris
Sony Vegas is rendering black screen
By LoveMyslf in forum EditingReplies: 20Last Post: 24th Jun 2015, 08:59 -
Sony Vegas pro 9. Rendering Black screen
By jolehoz in forum EditingReplies: 0Last Post: 15th Nov 2010, 12:02 -
Black Magic Intensity + Sony Vegas Pro - newbie help
By Coroni in forum Capturing and VCRReplies: 34Last Post: 28th Jul 2010, 03:00 -
Dell I7 with vista gives black screen of death
By troyvcd1 in forum ComputerReplies: 9Last Post: 30th Apr 2009, 19:36 -
Sony Vegas Pro 8.0 - why is preview in Black & White only
By hondaspeedx in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 13:19
