Hi
I have burned about five or six dvd's from mpeg2 files (which play perfectly on PC) to DVD usi8ng AVStoDVD but there is no audio on them. Please check the log I post below.
Any help would be much appreciated!
Aikipaul
PS: I tried to post this same thread once and it didn't seem to take. my apologies for double post if it happens.
log: is uploaded
I may have missed something, but the log shows that the audio was converted and added to the video files. It appears the audio is "AC3 - 256 kbps - CBR - 44100Hz - 2ch" and was converted to "AC3 - 192 kbps - CBR - 48000Hz - 6ch". I would check one of the burned DVD VOBs with MediaInfo to see what audio is listed. Not sure why it is converting two channel to six channel, but I'm not that familiar with that program.
And welcome to our forums.
@aikipaul
welcome here. Some questions:
1. What AVStoDVD release are you using? It should be 2.2.0 and latest one is 2.3.1. Please use 2.3.1
2. Audio seems to be encoded and authored. Have you tried to play the disc on a standalone DVD player other than a PC?
3. If you use the 'Title Preview' feature, do you hear sound?
4. (Just curious) Title 17 is 1 second long... is that ok?
Bye -
@_MrC_ I downloaded 2.3.1 and I get the same results. I am trying to play the disc on a standard DVD player and I get video without any audio. I can see that the audio files re being encoded but I'm not sure why they are going in as 6 channel. I'll try to use a different audio encoder to see what happens. Is there any other mpeg to DVD burning tool you can recommend?
Thanks for all your help,
Aikipaul
No Audio when converting MKV to DVD using AVStoDVD?
By |StarscreaM| in forum Video ConversionReplies: 14Last Post: 8th Jan 2013, 23:57 -
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 13:52 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
[Help - Log inside] Having issues burning on Dell M1330 with Vista using
By dellfanboy in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2008, 20:14
