I have a Dell Dimension 2400 with a NEC 2100AD DVD writer. This drive will play all DVD's but will only write to DVD+R. I have heard that it is possible to "flash" the firmware and/or drivers that will allow it to write to DVD-R also. Is this possible? If so, may I have some new bee dummy how to instructions please.
THX
DBM
check out my videos:
http://www.youtube.com/user/DirtBikeMikeHubbard -
your dvd burner is a older model....better to just buy a new dvd burner which you can get for under $20.00 from Newegg...if you flash a dvd burner incorrectly the drive is dead.....IMHO buy a new burner.....Just my 2cents!
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=5&name=CD-DVD-Burners -
Thankx Budz for the help and link. I will get a new one from New Egg. Should I set the new burner up as the slave or master on the IDE cable?
It certainly was possible to do this. I had a NEC burner that came with HP PC that I bought about 5 or so years ago and I had to do that to it. It worked fine after flashing it. Honestly, that NEC was one of the best burners I've ever owned. But you might want to consider budz' idea. Your burner is pretty old if you have to even consider this. They haven't made +R only and -R only burners in years. The newer Samsung burners are pretty good.
Thankx for the help fellas. Just ordered a Samsung IDE burner for 17.00. Should I set it up as a slave or master?
set up as master...buy a new 80 wire ide cable as well....newer ide dvd burners require them...
http://www.svc.com/md-24-ata-3bu.html
Dell inspirion DVD+RW can't read commercial DVD's
By Super Leviathan in forum DVD & Blu-ray WritersReplies: 9Last Post: 20th Feb 2012, 08:18 -
DVD Dell Inspiron writer drive .. blue screen
By holeepassion in forum DVD & Blu-ray WritersReplies: 14Last Post: 4th Sep 2011, 20:30 -
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 00:50 -
DVD Writer won't write
By hcs in forum DVD & Blu-ray WritersReplies: 4Last Post: 21st Nov 2007, 04:46 -
DVD Burner for a Dell laptop
By PhoneMatt in forum ComputerReplies: 5Last Post: 26th Oct 2007, 12:15
