I was given one of these without a remote control. I intend to keep it, as I found it plays dodgy VHS tapes that
don't work on 3 other VCRs in my shed. Unfortunately with no remote controller, you can't do most of the things
of which it is capable. Before I buy a remote controller, I wish to be sure it will work. I bought one before for
something else, and it was crud: only the basic play/rewind/stop functions worked, you could not get a setup menu.
Has anybody used one of these with a "universal remote"?
I have the es46v model. I have a logitech harmony remote and I was able to program it so that I can use all of the menu functions in the dvd/vcr combo.
Check out ebay or another auction site for a used logitech harmony remote. I have a 520 series model that does quite a bit. I would think anything in the 500 range from logitechs harmony series should be relatively inexpensive online. THan you can fully program the remote on your computer for the exact model you have without the original remote.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 32Last Post: 9th Jul 2018, 22:15 -
Panasonic DMR-ES35V
By RobJenk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Dec 2010, 14:42 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 18:50 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 16:27 -
help for PANASONIC DMR-ES35V ......PLEASE!!!!
By samjc2007 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2007, 12:35
