Hi, Will my PS3 play region 1 dvd's?
Ta!
If you bought the PS3 in the USA or Canada then the answer is "yes".
I am guessing that Berkshire is probably in the UK, in which case the accurate answer is no - the PS3 will be resolutely Region 2 and unchangeable. However it will handle NTSC, in which case you can rip the disc to your HDD, removing the region code from the disc, then burn it to a new disc which will play in the PS3. I do this to get around the same issue with my Region 4 PS3.
Read my blog here.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 14:24 -
Can a PS3 play Blu-Ray region free dvd?
By Minx4MadMen in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 18:15 -
1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3
By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 04:10 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 13:48
