  1. Hi,
    I am trying to make a tutorial with Camstudio. After a good AVI is made (works perfectly) I import it in Vegas 9 to put some text with it.
    After rendering my video is getting a lot of unwanted colors.
    See this video (46 seconds): From 17 seconds you can see it. http://www.youtube.com/watch?v=zHhnJ6ntaC0
    How do I solve this?
    Arjan
    Apr 2004
    Miskatonic U
    If you scroll to those points on the Vegas timeline, and zoom down to the frame level, what do you see ? Are these on timeline ?
    What format are you rendering to ? Do these distortions appear in the your rendered video prior to uploading to youtube ?
    Read my blog here.
  3. If you scroll to those points on the Vegas timeline, and zoom down to the frame level, what do you see ? Are these on timeline ?
    >> Yes they are!
    Windows Media V11
    6mbps HD 720 30p
    framerate 29.970
    seconds per keyframe 3
    quality 100%
    Yes I see it in Vegas and after rendering I also see it.
    I do not see it in the original AVI and also not when I upload this original AVI to You Tube.
    Tnaks for your help!
    Apr 2004
    Miskatonic U
    The issue would appear to be in how Vegas is interpreting the camstudio footage. I assume you are capturing directly to the camstudio codec ? If not, to what codec ?
    Try loading the avi into virtualdub. If it loads and looks OK there, you could then output to a lossless codec like huffyuv or lagarith, and then load this version into Vegas.
    Read my blog here.
  5. Vurtual Dub did the trick! I used the codec: lossless codec 1.4!
    Thanks for the help!
