Hello I'm a bit of a newbie at this so please be gentle
I have a Region 1 DVD and want to rip it and then burn it onto a single layered DVDR that will be playable on a Region 2 player. I have ripped it with DVD Decrypter and I know have a 7.36Gb Image File.
My question is will this image file still be region 1 encoded or will I need to rip it again with some special settings or using another program?
Any help is much appreciated.
DVD Decrypter removes the region code by default. Region 2 covers a wider geographic area, including Japan - which uses NTSC like region 1 - and the UK - which uses PAL. Simply changing region code does not alter the format (NTSC vs PAL). Most PAL players will play NTSC material, but not all. So while you have removed the region code, and the disc will most likely play in a region 2 PAL player, there are no guarantees.
Read my blog here.
I VERY STRONGLY recommend that you do the following and do NOT deviate from this.
1) Burn ONLY to Verbatim DVR+R DL discs.
2) Use ONLY the free program ImgBurn to burn with.
If you deviate from these 2 instructions and your disc doesn't play, well, I warned you. -
I don't have DL discs and I don't think I could even burn them if I did have them...
Thanks for the warning though
So he is going to need something to "shrink" down the file.
DVD Shrink, DVD Rebuilder, etc.
If you want to keep the best possible video quality, do the movie only, getting rid of extras, extra audio tracks, menus, ect. -
Thanks yeah I was going to use DVD Shrink. As I said in the first post I'm really pretty new to this. I've only used Nero before to create and copy DVDs. This is my first back-up of a copy protected one.
Yeah Nero kind of sucks.
The easiest way is to just load the VIDEO_TS folder or the ISO/Image file into DVD Shrink then select "Re author" and you can drag the main movie only over to the left window and let it do it's thing.
It's really easy and pretty self explanatory if you just look it over.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Making a Region 1 Player Region Free. Can't find code.
By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 08:28 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
