    Dec 2007
    Brazil
    I'm using MeGUI to convert some videos to mp4, using the AviSynth script like this:
    DirectShowSource("Movie.avi", fps=23.976, audio=false)
    TextSub ("Subtitle.srt")
    I have the K-Lite Mega Codec pack installed, when I open this script in MeGUI legend is white, wanted to change the color and font used, how?
    Change it in the vsfilter / vobsub settings. Check for a green arrow in the taskbar notification area while playing/preview the video with subs or check if klite has added any vsfilter setting shorcut in the start programs.
    Dec 2007
    Brazil
    Good night, here at K-lite has the option to edit the DirectVobSub, but does not change the caption, as the filter seems not to be used ... I am following the tutorial to do the encode, because the filter is loaded for the dll vsfilter.dll, only where it sets I do not know = /
    Thank you for your attention.
    [EDIT] problem solved, I got into editing the legend. Subresync srt even that comes with VobSub, simply edit, save, and presto, all settings are on them, i just add the filter with normal TextSub (Movie.srt)
