Curious about doing this to use audio as ring tone.
Use a tape player that has a mini jack output and plug the other end into the LINE IN of your computer's soundcard. Any audio editor should record it. A noise reduction filter could be applied to remove any hiss.
A ring tone will be a butchered version anyway, so don't get too into cleaning it up to sound "perfect".
Cell phone speakers are all pretty much crap.
Wasted effort on that front.
Tape player, line in, and Audacity will work for free.
There are better methods, however, for archival quality transfers.Want my help? Ask here! (not via PM!)
I would suggest that whatever format you need for ringtones that you end up with the ringtone file being in mono. You'll gain nothing by having a stereo ringtone. Mono will take up less space. Typically cell phones don't have a lot of storage so saving even a little space might be useful. Also if your cell phone supports it, I would strongly recommend that you use 44.1 Khz or higher for the sampling rate and not use a lower sampling rate unless your phone demands it.
video cam can suite 8mm tape/cassette
By happytony in forum Video ConversionReplies: 1Last Post: 24th Aug 2011, 00:33 -
By happytony in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Aug 2011, 23:55 -
cassette audio tape
By zoobie in forum AudioReplies: 7Last Post: 4th Jul 2008, 00:06 -
Broken Cassette Tape Repair
By SCDVD in forum Newbie / General discussionsReplies: 8Last Post: 11th Nov 2007, 12:38 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 16:48
