I have searched the forums and am yet to find it... Sorry if it already is.
Ok,
So, to setup I run an HDMI splitter from my Xbox 360. From there I run an HDMI cable from the splitter to my TV's HDMI 'IN' and also to the Intensity pro HDMI 'IN'. From the Intensity Pro I run an HDMI cable from the Intensity Pro's HDMI 'OUT' to my laptops HDMI 'IN'.
Is the above true in where to run my cables etc?
From my laptop do I run Blackmagic Media express or programs of the like?
Thanks for your help. Please respond quickly
-SkinnyRabbit
P.S - My laptop's specs are as follows:
Windows 7 64bit,
Intel Core i7 Q740 @ 1.73GHz,
6GB RAM,
1TB HDD, ATI Mobility Radeon HD 5870.
Results 1 to 11 of 11
The Intensity Pro is a PCIe card. You can't use it with a laptop. Your laptop's HDMI port is an output, not an input.
Ok then, what other HDMI capture cards can be used?
Simple and easy to use. Can you also point me to a tutorial on how to setup as well?
Cheers
-SkinnyRabbit -
If your laptop has a USB3 port you might be able to use the BlackMagic Intensity Shuttle. Otherwise, I'm not aware of any HDMI capture devices that will work in a laptop. The BlackMagic Intensity and Avermedia AVerTV HD DVR require a PCIe slot -- generally only available on desktops.
You can use the Hauppauge HD PVR to captuer HD component output from the Xbox 360. But you'll need a second display that accepts component input (ie, HDTV) because there's a ~1 second lag between the game and what you see on the computer monitor.
skinnyrabbit,
Where exactly is the BMIP? You seem to be all right until you mention a laptop...Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
How/where do you have your BMIP installed.
- 360 to splitter, check
- splitter to TV, check
- splitter to BMIP in, check
This should be all you need, but, then you:
- BMIP out, to laptop? Why?Have a good one,
neomaine
I've got it now. He's just got the card sitting on his desk and simply daisy chaining the cables. How silly of me...
Have a good one,
neomaine
That's what I was gonna do neomaine. I'm so sorry i'm not as nerdy as you are... Let me bow down...
I was actually kidding. But, now that you know your place...
Were you really going to have a PCIe card laying on your desk not installed in a desktop and expect it to work? Sorry, but, you kinda deserved that one. Chalk it up to a learning experience.
If you don't have a desktop and only a laptop then you'll need an external device. I've never used one but an number of regulars here speak about a Hauppage HD PVR.Have a good one,
neomaine
Blackmagic Intensity Pro - Xbox 360 to PC capture audio issues
By xmadmardiganx in forum Capturing and VCRReplies: 71Last Post: 22nd May 2011, 18:28 -
blackmagic intensity pro xbox 360 help
By tehshame in forum Capturing and VCRReplies: 11Last Post: 18th Nov 2010, 15:24 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 17:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum Capturing and VCRReplies: 0Last Post: 22nd Apr 2009, 15:27 -
blackmagic intensity / Xbox 360 / Adobe premiere pro CS 3
By jonakangou in forum Capturing and VCRReplies: 11Last Post: 17th Jul 2008, 00:42
