  1. Hi All,
    I have .h264 (High profile and Main profile encoded file) raw video file and aac audio file - and i need to put this into Blu-ray container so that i should be able to play this in any Blu-ray player (sony or samsung) is this possible ? if so then please let me know the software to put container on this..
    Is there any min video resolution (lowest possible resolution) in the Blu-ray spec....
    fido
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    make an avchd.
    use multiavchd.
  3. HI Yoda,
    Quick question.. Is it possible to encoded 320x240 (qvga ) resolution video into blu-ray format. wondering whether Blu-ray supports 320x240 resolution.. is there any resolution limit in it...
    thanks
    fido
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Nope:
    https://www.videohelp.com/hd
    Video frame size
    High Definition Video
    1920x1080x59.94i, 50i (16:9)
    1920x1080x24p, 23.976p (16:9)
    1440x1080x59.94i, 50i (16:9) AVC / VC-1 only
    1440x1080x24p, 23.976p (16:9) AVC / VC-1 only
    1280x720x59.94p, 50p (16:9)
    1280x720x24p, 23.976p (16:9)
    Standard Definition Video
    720x480x59.94i (4:3/16:9)
    720x576x50i (4:3/16:9)
    It must upcoded to the minimum sd specs that bluray allows - 720x480x59.94i for ntsc - 720x576x50i for pal
    Sep 2010
    Malaysia
    You can upscale the video to SD 480p or 720p and burn to DVD and play in BluRay Player or copy to SD Card and play from the Bluray player or Viera's SD reader. See http://allaboutvideo.weebly.com/convert-to-hd-for-viera.html. Site still incomplete but almost done.
