Right now I'm using handbrake, it's not too bad and it's served me fairly well.
But since I've starting recording in 1280x720, I wanted to make sure I could get the best quality to size ratio.
Any particular settings I can tweak?
Thank you in advance!
There is no "best" setting. It's all trade-offs. You decide for yourself what trade-offs you want. Size v. quality v. encoding time.
CRF19 is the best choice under high quality settings (more refs, higher RDO, trellis=2). The stronger the settings, the lower CRF you can go without risking oversizing.
30 FPS What is the optimal setting? Is it a tradeoff bet. filesize & smooth
By etbrown4 in forum Newbie / General discussionsReplies: 5Last Post: 21st Sep 2011, 17:22 -
Problem setting up Handbrake
By PhoneMatt in forum Video ConversionReplies: 7Last Post: 15th Mar 2011, 11:29 -
Anamorphic Setting in Handbrake - I'm Confused!
By w6rlf in forum Video ConversionReplies: 1Last Post: 20th Feb 2010, 12:06 -
Handbrake H.264 question
By stiltman in forum DVD RippingReplies: 21Last Post: 21st Sep 2009, 13:34 -
help converting 2Tb of videos to H.264 (size/quality/tools)
By Prophes0r in forum Video ConversionReplies: 3Last Post: 13th Aug 2009, 23:05
