I have been copying my dvd's and saving them as a DVD folder (VOB format) for years. What are the advantages of saving a movie as an ISO image? I'm pretty sure the quality of the copy is the same.
I don't really think there is an advantage. It's really just a disk image of the video_ts file structure.
ISO files were in use as generic disk images long before they started to be used as video/audio "containers". -
There is also the NRG file. I guess it's also another container.
The only advantage of an iso file is to keep the files in one container file so no files are lost in case of accidents.
ISO is a disadvantage if your using a remote Hard Disk with a fat format. Can only put ISOs on it smaller than 4 gb. Also some players prefer TS folder
But as JohnsO said above.. with only 1 file it's easier to keep track of and you have less of a problem loosing something.
I generally use TS folders for stuff on hard disks. That way with episodic DVDs I can just choose a specific vob file to play.
ISO vs TS folder.... best thing is it doesn't take much time or effort to convert them back and forth. And it's all lossless.
Tony
advantages of transcoding mpeg2
By codemaster in forum EditingReplies: 4Last Post: 26th Apr 2012, 17:11 -
Advantages of using M2TS over .TS with TSmuxerGUI
By jack616 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2011, 12:35 -
Analog TV-Monitor Advantages?
By therock003 in forum Newbie / General discussionsReplies: 37Last Post: 27th Jan 2009, 17:57 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
