  1. (convertxtodvd transcoder) 0xc00d0bc5 transcoding error; convert transcoder not responding; convert x as encountered a problem and has had to close .when i try to open it i get the error.thanks any info on this . xbill Click image for larger version
    Please give more information.
    Latest version? Has it worked fine before?
  3. version3.3,4, worked fine ,tell today.all i get is error .
  4. version3.3.4 it worked fine.
    Oct 2007
    Try uninstalling convertxtodvd with the scrubber tool then reinstall. This tool will will completely remove any trace of VSO products from your system and allow you to start with a clean slate.... The tool is kind of old now but still worth a try.
    http://forums.vso-software.fr/how-to-completely-uninstall-convertxtodvd-t5055.html
  6. i did that also.
