Results 1 to 9 of 9
    Sep 2010
    Liverpool U.K.
    When I add asset I get message ffmpeg has stopped working. Any help would be most appriciated..Thanks
  2. Have you tried reinstalling the program??
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Sep 2010
    Liverpool U.K.
    Yes reinstalled but just the same. i cant undertand it, I have been using SVCS2DVD for some years but this has just happened out of the blue
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is it a certain asset or is it all assets?
    Sep 2010
    Liverpool U.K.
    HI,
    It all assets
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have PM'd you a new build to try.... However, what path do your assets have that you are adding?
    Sep 2010
    Liverpool U.K.
    Hi
    I have tried the new build but its the same
    The path to my assets are C:windows\documents\movies
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What OS are you using?
    Sep 2010
    Liverpool U.K.
    I am using windows 7 but I have been using VCD2DVD with win 7 for months with no problem at all
