  1. Hello Guys
    I have a the same structured DVD Ripped files on my Harddisk. (VTS_Video, Audio Folders etc.)
    I want to select the chapters and extract the AC3 Stream from that chapter.
    Which Programm can do it?
    Thanks for your Help
    DVD Audio Extractor
    I don't know any easy free solution, dvddecrypter might work but it can only open a dvd drive. Or DVD Shrink and in the authoring mode choose the chapters, save as a new dvd, use pgdemux to demux the ac3 from the created dvd.
  3. DVD Audio Extractor can only extract it from a DVD Drive???
    But i need it to extract from DVD File.
    Ok i try other programs.
  4. PGCDemux can get the audio from chapters with the DVD already on the hard drive. Rather than demuxing the audio by the PGC though, select the right cell (chapter) to demux.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How about just dragging the VOB into Goldwave then saving it as something else. You're not gonna keep it as AC3 are you?
  6. ok thanks i will try PGC
