Tried converting few mkv (HD) file to avi (divx HD) using DVDFab / ImTOO Video Converter ... the converted file was almost double the original file size ... any suggestion where i might be going wrong?
Results 1 to 18 of 18
Could you maintain the same size and quality of the MKV file as an AVI or would you have to halve the bitrate and thus quality? Would it matter quality-wise if the video was being burned onto a DVDR to be played in a DVD player?
I ask because I have some MKV files that are from HD streams and I want to keep the quality as best as I can but I'm burning to DVD so will be converting. -
Just about anytime you do an re-encode, you lose quality. If the bitrate is the same, then more quality loss. You generally have to increase the bitrate to keep quality. MKV is a very efficient encoding format, and converting it to Divx or Xvid at the same bitrate will lose a lot of quality. Double the original size is about right most times if you want the same quality.
If you are converting HD material (1080 or 720) to standard DVD Video format then you will lose quality - noticeably - and this cannot be prevented.
AVI and MKV are just containers. The content is compressed based on the codecs used. For example it is possible to use both Xvid and MP3 for video and audio compression in both AVI and MKV files. Therefore you can have identical video and audio content, and the only difference in file size will come down the overheads of the containers themselves.
When comparing content encoded with different codecs, all bets are off. Some codecs compression much more efficiently than others - H264 produces much smaller files than mpeg-2 while maintaining the same quality, for example - and some codecs compress well, but have image trade-offs - Xvid/Divx, for example.Read my blog here.
Originally Posted by denniscool
If you do want to do avchd (high def on a dvdr) use multiavchd. It supports mkv as an input - in fact I'm using it right now to convert an hd-mkv file to avchd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thank you. I think this is what I want. Are you saying that I can add MKVs into that and burn it as AVCHD and it'll play on my DVD player? Would I be losing much of my quality? I have Nero 8 which has AVCHD burning capabilities but doesn't support MKV...
Originally Posted by alan rouge
If the mkv is already the size of a dual layer you SHOULD be able to stick it in multiavchd and output a avchd to dual layer dvdr in quick order.
If its larger it will have to be transcoded to fit (multiavchd has a fit all option to fit to single layer or dual layer - though it takes time to process if its larger than the source file).
There may be instances that your mkv may need to be converted if its not a regular hd file - ie 1080 or 720 (if its an odd resolution it may have fits over it).
EDIT - SO FAR AS I KNOW AVCHD IS FOR BLURAY PLAYERS ONLY!!! That includes pcs that can play hd and of course a playstation 3. There may be special dvd players that can play avchd but there aren't any that I know of.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
AVCHD on DVD so far is only supported on bluray players (including the PS3), and not all bluray players at that. It is not supported by DVD players.
If you are going to create AVCHD discs, do as suggested above and use MultiAVCHD, then burn with Imgburn.Read my blog here.
Actually I was just looking at Multi-AVCHD there and I see there's an option for "SD DVD for DVDR"
Does that convert the MKV files to MPEG2 or something? -
If you don't have a bluray player you can look into a harddrive media player like a wdtv media player. It can play mkvs directly off a usb ntfs harddrive and are generally cheaper than a bluray player (around a 100.00 USD new - used models will be cheaper). There are many competitors now but make sure the brand you look at can play high def files. Also note some don't have component out - hdmi only - so if you have a hdtv without hdmi that would be a consideration for you.
EDIT - alan rouge - yes it can output to standard dvd BUT IT WILL NOT BE IN HIGH DEFINITION.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Ah right thanks again. For the moment I literally just want to get these MKV files onto a DVD to give to someone. They're only small, about 100mb. They are live performances of some songs which were taken from a HD source.
I doubt I'll be getting a hard drive player anytime soon but cheers for the info. -
As long as they have a computer that can play mkv - mpchc or vlc for example - just burn it as data with imgburn. They can play it straight off the dvd on the computer or copy them to the harddrive first then play.
Though for smooth hd playback they should have at least a dual core processor to do it without stuttering.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Nah it's to be played in a DVD player.
On a related note, do you know how I could split up an MKV file? I have a half hour music show but only want to take out about 10mins that I need. -
Check out the tools section:
https://www.videohelp.com/tools
I can't think of a tool off the top of my head to cut mkv files. THere are lots of mkv specific tools you can use but at the moment I can't think of one to just chop it up.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
just want to say data of pressed file still in the file you pressed its just out of reach. its not like you making something new like from cd (Flac) everything's possible just to complicated to explain in writing. All the best boys and girls keep the progres, like someone said concurrence promotes perfection. -
size avi, mp4, mkv
By hotsprout in forum Newbie / General discussionsReplies: 7Last Post: 18th Jul 2015, 13:25 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Optimal File Size BD-> MKV/MP4.
By nirbhayn in forum Blu-ray RippingReplies: 5Last Post: 24th Aug 2011, 07:31 -
Converted MKV Doubles in Duration PS3
By diesel.1 in forum Newbie / General discussionsReplies: 0Last Post: 7th Dec 2010, 04:14 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44
