Everytime I restart my computer I get an error with
RUNDLL at the top
Error loading C:/windows/memprm.dll
The specified module can't be found
Any ideas on what is causing this?
THANKS
virus or trojan infection most likely
Sounds like your virus program removed the file but not the registry setting,look on google how to remove that line from the registry if that's the case.
I agree with the partial removal from virus cleanup. If you're comfortable or familiar with editting the registry you should use a tool that will at least let you see startup programs.
One of my favorite reasons for using Spybot Search&Destroy is startup tool. Use the advanced setting and go to tools and use the system startup. Should be readily visible and simply delete. Of course, make a backup of your registry first....Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
OK, what tool do you recommend I use to view start up tools? I usually go to run then msconfig. Is this not what I need to do? If so, what do I need to be looking for?
I created a system restore point, is this all I need to do to back up my registry? Can I just run the spybot now with the steps you listed or is there somthing else I need to do?
Thanks for your help, sorry for all the questions! -
msconfig should be fine. Just go to the startup tab and look for the offending .dll. Though this will only disable the entry and not remove it if I remember right. Otherwise, see my previous post.
Have a good one,
neomaine
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 12:04 -
MPEG2.dll
By Black-Logik in forum Video ConversionReplies: 6Last Post: 21st Mar 2009, 03:40 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28
