Hello! I wanted to convert our VHS-C tapes to DVD as a Christmas present for the family. We have about 30 tapes, however, all the places I found online that will do this (conversion with chapter placement, etc.) for you are in the $600 range. Is there a cheaper way for me to do this on my own?
I understand the basic steps are 1)getting the video onto your computer 2)editting the video in some sort of video-editting software 3)Burning the disc to DVD
I have a VHS-converter tape that allows me to play the tapes in a VHS player. I have an IBM Thinkpad computer with Windows 7, Intel(R) Core(TM) i5 CPU M520 @2.40GHz, and 32-bit Operating System. My computer also has Windows DVD Maker.
1) How do I get the video onto my computer to edit?
2)Would it be easier/cheaper to have a company or friend with a DVD recorder copy the raw footage onto DVD and then edit it myself and add chapters in Windows DVD Maker?
3) Is Windows DVD Maker a good software to use or should I buy a better software?
4)I would like to make each seperate event on the videos as a separate chapter. For instance, on one video tape there are 2-3 different events. Is there a way to separate these in Windows DVD Maker (or another software) to make each separate event a separate chapter?
Any information would be very helpful! thank you!
Windows DVD maker is fine for general use, but if you want to edit them a program like Sony Movie Studio would be desired. To get the video to your pc you'd need a video capture card, this will generally produce better quality than a usb video capturing device.
Since you are asking this question, I would suggest using a standalone DVD recorder.
You can then copy it to the computer if you want to edit it.
I suggest TMPGEnc DVD Author (Authoring Works) to edit. You can trim, cut, and easily place chapter points. Also creates menus. Download the free trial version to try if first.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 01:16
