  1. I'm trying to download some videos from sites. One of them ( xxx's ones ) can not be downloaded using from conventional programs, just like DownloadHelper or xVideoServiceThief ( both of them are great !!! ).
    So, I could try using Cometbird method. In my first tests, I could be succeed.
    If you wanna try it as something optional, feel free.
    If this program / method can always work, I do not know. :P
    ---> http://www.cometforums.com/topic/12793341-using-cometbird-to-download-videos/
    ---> http://www.cometbird.com/page/features-video-download.html
    One of CometBird's advantages is to download video/audio/flash from websites. In this topic, I will tell users how to download media with CometBird and what needs to be paid attention to:
    1. Download and install CometBird.
    2. Navigate to the webpages that contain the embedded video/audio/flash with Cometbird.
    3. Play Video/Audio/Flash you want to capture.
    4. After the video/Audio/Flash finished playing, please right-click and select Download Media Files in the menu list.
    5. If you strictly followed the previous steps, the video file will be captured. And you need to check the video name and click [File format---File size---File name], CometBird will download the video you selected to your local disk.
    Please read more and watch the video guide HERE.
    NOTE: Please do remember to Play the video first and then right-click in the area outside the video frame. Some users say their CometBird can not capture the video name they want to download. It's usually because they do not pay attention to these two points.
    Thanks.
    devil (johner)
    Mar 2010
    Nicosia
    Just download with IDM(internet download manager) its work for all videos
  3. Hi... It's that one? It can dowload all kind of flv sites? I'll try and share my results...
    ---> http://www.internetdownloadmanager.com
    Thanks.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Originally Posted by devilcoelhodog View Post
    Hi...
    Where I can get it? Where's the official page?
    Thanks.
    http://lmgtfy.com/?q=internet+download+manager
    Mar 2010
    Nicosia
    yes it is.
  6. I had used Jaksta Streaming Media Recorder and Converter to test it and I could "grab" some videos
    I was having issues to do so using other programs methods mentioned previously.
    For some specific sites I have tried to grab, Jaksta was the only method/program I could succeed until now. :P
    Thanks.
