I just converted a 2 hour VHS to DVD via my Magnavox ZV427MG9A DVD Recorder & VHS Recorder. Now I would like to put the DVD into my PC, edit it and then create a new DVD with my PC’s DVDRW. What software do I need for the editing?
	Tmpgenc DVD Author, Videoredo Tvsuite or Mpeg Video Wizard DVD.
 Or are you looking for free solutions? Then you could use vob2mpg and try edit with Windows Movie Maker or Pinnacle VideoSpin.
	http://tmpgenc.pegasys-inc.com/en/product/tme3.html
 is great if all you want to do is edit out commercials as it does not re-encode and if you do not want fancy menus, or spend the extra $35 and get the author works.PAL/NTSC problem solver.
 USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
	Recorded family video VHS/DVD, it plays on the recirder, but won't play on PC or another DVD player, disc was finalized
	I've seen this before, you say your PC can't play the disk (I'm assusming you software player has issue with the disk) but can it read it.
 If so copy the main vob files to your hard drive. U can try DVDshrink as it has a movie only option. If it fails try imgburn or isopuzzle to create an image of the disk. Once the vobs are on your hard drive use vobmerg to combine the main movie into a single vob. Then you can cut and edit the video in something like Cuttermaran or mpegschnitt Save your edited video then author Simple DVD Creator (if the resulting file is not compliant use DVD Flick instead).Murphy's law taught me everything I know.
  What editing software to use after transferring VHS to DVD?By garyg45 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Mar 2012, 11:20
  VHS to DVD to computer for editingBy JoeCB in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2010, 17:52
  Any considerations when burning WinAvi converted dvd to a DVD+RW?By AshleyQuick in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:31
  Video editing & burning softwareBy katz68 in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 16:58
  transferring old vhs tapes to computer for editing and burning to dvdBy michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 12:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
