HI MrC,
I successfully demuxed the audio and video. I tried to put it back into an mp4 container,
but YAMB didn't like it. SO I made an MKV instead.
AVStoDVD tried to index it as before, but it didn't pickup the audio.
I tried using the old method, and it created the DVD, but the DVD has sound but no picture,
just a gray screen. Here's the log:
PS if you want to try yourself with the MKV, I can post it for you - it's 187 MB
<9/30/2010 12:08:41 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 45/4450 MB (1%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: I:\dvd-copy
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: True
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: H: _NEC DVD_RW ND-3540A 1.04
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: F:\Documents and Settings\Dave Xnet\Desktop\CLP_0032_01_track1.mkv
Info: MPEG-2 Video - 36750 kbps - 1920x1080 - DAR 1.778 - 25 fps (CFR) - Progressive - 43 seconds - 1076 frames
Audio 1: F:\Documents and Settings\Dave Xnet\Desktop\CLP_0032_01_track1.mkv
Info: PCM - 0 kbps - CBR - 2ch - 48000Hz - 16bit - 43 seconds - Internal
Subs:
[MediaInfoLib - v0.7.35]
AVISYNTH SCRIPT
Import("F:\Documents and Settings\Dave Xnet\Desktop\AVStoDVD_232Alpha100910_NoInstall\Lib \A2DSource.avsi")
Video = A2DVideoSource("F:\Documents and Settings\Dave Xnet\Desktop\CLP_0032_01_track1.mkv", CacheFolder="K:\Temp", VFR=false)
Audio = A2DAudioSource("F:\Documents and Settings\Dave Xnet\Desktop\CLP_0032_01_track1.mkv", CacheFolder="K:\Temp")
Video = Video.ConvertToYV12
Video = Video.Spline16Resize(720,576)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 43.6 MB
QuEnc Parameters: -i "K:\Temp\DVD_5_CLP_0032_01_track1_1.avs" -o "I:\dvd-copy\DVD_5_CLP_0032_01_track1.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<9/30/2010 12:10:13 PM>
END VIDEO ENCODING OPERATIONS
Created File: I:\dvd-copy\DVD_5_CLP_0032_01_track1.m2v (43.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x576 - DAR 1.778 - 25 fps (CFR) - Progressive - 42 seconds - 1072 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "K:\Temp\DVD_5_CLP_0032_01_track1_1.avs" - | "F:\Documents and Settings\Dave Xnet\Desktop\AVStoDVD_232Alpha100910_NoInstall\Aft en\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "I:\dvd-copy\DVD_5_CLP_0032_01_track1_1.ac3"
<9/30/2010 12:10:48 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: I:\dvd-copy\DVD_5_CLP_0032_01_track1_1.ac3 (1 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2ch - 48000Hz - 16bit - 42 seconds
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "K:\Temp\DVD_5_BatchMux.ini"
BatchMux ini file:
-d "I:\dvd-copy\DVD_5\VIDEO_TS"
-mxp "K:\Temp\DVD_5_MuxMan.mxp"
-l "K:\Temp\DVD_5_MuxMan.log"
-muxman "F:\Documents and Settings\Dave Xnet\Desktop\AVStoDVD_232Alpha100910_NoInstall\MuxMan"
-prio LOW
-v "I:\dvd-copy\DVD_5_CLP_0032_01_track1.m2v"
-vidmode LB
-a1 "I:\dvd-copy\DVD_5_CLP_0032_01_track1_1.ac3"
-a1lang en
<9/30/2010 12:10:51 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 45.2 MB
vs Estimated Size: 45 MB -> 0.4% oversize
vs Assets Size: 44.5 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: I:\dvd-copy\DVD_5 (45.2 MB)
Log file created by AVStoDVD Release 2.3.2 Alpha build 100910
EDIT I should add that the program worked successfully after I set FFMpegSource in the preferences.
Results 31 to 33 of 33
Well, you have found the clue by yourself when you have successfully tried FFMS instead of A2DSource: the latter tries first to use AVISource, then DSS and at last FFMS. Probably DSS reads your mpeg2 but the decoding chain fails giving you a gray picture.
Another option could be to keep the indexed d2v file and add the wav audio track manually (not sure, but I suspect that DGIndex is not able to demux audio from matroska containers).
Bye -
Well I noticed the Nvidia Purevideo decoder was being used for decoding. I uninstalled it and the system reverted to a Nero
codec. After I did that, AVStoDVD works fine with this file on A2dsource and DirectShowSource now.
Perhaps there was a conflict somewhere - Seems OK now .
Cheers,
Dave
Looking for tips on use of ASFbin
By Seeker47 in forum Video ConversionReplies: 0Last Post: 22nd Dec 2010, 11:23 -
tips for exporting/rendering videos to be burned to DVD's?
By johnphenomenon in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2010, 21:03 -
Need Rendering Tips!
By reece_wallace in forum EditingReplies: 1Last Post: 31st Dec 2009, 00:15 -
pc tips n trix
By allenstreet in forum ComputerReplies: 3Last Post: 22nd Jul 2009, 19:41 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 12:10
