Hi.
I read on Wikipedia that Final Cut Pro requires Intel processors. Is this true? If I have a computer with AMD processor, it won't work at all?
Thanks.
Results 1 to 9 of 9
Final Cut Pro only runs on Apple MAC OSX.
http://www.kiva.org/about -
Thank you, guys, but that's not what I asked.
If there is a Mac (or a PC, I don't care) with an AMD processor inside, will Final Cut Pro work at all (given that there is that AMD processor powering the respective computer)? Do you know?
I didn't say one word about hacinposh, or other things like that.
Thanks again. -
Final Cut Pro only works on the Mac OS X
Mac OS X only runs legally on Apple Mac computers
Apple Mac computers use Intel CPUs. There are no AMD Apple Mac computers.
If Apple says FCP does not run on AMD processors this could mean
1. That it simply has not been tested on AMD processors because there are no AMD powered Macs to test it on. Therefore Apple cannot guarantee that it will work
2. That is has been tested on an AMD based test system and found not to work
3. That Apple simply do not want you using FCP on non-Apple hardware, and have deliberately knobbled it so it cannot run on AMD hardwareRead my blog here.
In this particular case, it doesn't matter what you asked, because the facts (as guns1inger pointed out) make your question irrelevant. Final Cut Pro is a Mac-only product. There is no PC version of Final Cut Pro. Macs only use Intel processors, there are no Macs with AMD processors. Put all those facts together and you'll get your answer, if you actually bother to listen to what we're telling you.
Don't sweat the petty things, just pet the sweaty things. -
Final Cut has an interesting history. Originally known as KeyGrip when developed at Macromedia, later renamed to Final Cut, it was first shown in both Windows and Mac versions. When Apple acquired the project from Macromedia in 1998, the Windows version was dropped. The CPU processor wasn't the issue, Macs then ran on the Power PC. The decision to terminate the Windows version was a business decision by Apple.
See "History"
http://en.wikipedia.org/wiki/Final_Cut_Pro
Note that Apple has complete control of where Final Cut Pro will run since they control both the application and Quicktime for Windows. The hardware CPU isn't the issue. Compatibility starts at the OS level.Last edited by edDV; 26th Sep 2010 at 13:54.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Final Cut Pro
By masaeurope in forum ffmpegX general discussionReplies: 7Last Post: 10th Mar 2010, 17:58 -
Just Got Final Cut Pro 6
By The Monkees in forum MacReplies: 3Last Post: 14th Nov 2007, 13:24 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
