just bought a samsung hd tv (http://reviews.us.samsung.com/7463/LN37B550K1FXZA/samsung-ln37b550-37-1080p-lcd-hdtv-2...ws/reviews.htm) . and wondering if i can watch videos from pc to hd tv via dvi -hdmi.
my computer has a dvi output and the new hd tv has hdmi inputs.
So do i just buy a dvi to hdmi plugin cable? or do i need to buy a dvi to hdmi converter and plug that into the computer and then get a separate hdmi cable and attach it to the other end the the converter and into the hd tv hdmi port?
how audio? will there be audio? my new hd tv has a built in internal speakers. what can i do about audios if dvi-hdmi method doesnt provide it?
You can use a DVI-D to HDMI cable or a DVI-D to HDMI adapter and then an HDMI to HDMI cable.
Use the "Just Scan" setting on the Samsung TV for the computer input. Otherwise it will overscan.
Audio will be a separate connection. Line out to RCA (Red/White) in, or S/PDIF out to S/PDIF in.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
RF output to DVI/HDMI Input
By torrentkid in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2010, 03:41 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 10:44 -
Trying to connect laptop dvi outut to HDMI Input
By vettesea in forum DVB / IPTVReplies: 16Last Post: 8th Jun 2008, 16:53
