I own the 1st and 2nd seasons of Curb your enthusiasm. Upon buying them, I used DVD Shrink to back up each disc to single layer DVD-Rs.
Now one of the original DVDs is damaged (Season 2 Disc 2) and my backup is unreadable by ripping software. My backup DVD works just fine in my ordinary DVD player, however when I attempt to use DVD Shrink or Imgbrn to create an ISO backup, these programs both state that they cannot read the disk after about 18% progress. DVD decrypter, same thing. And when I tried Fair Use Wizard to rip to AVI, it failed right after it began.
Anyone have any suggestions as to how I could back up an already backed up DVD-R to my HDD as ISO or Video TS folder besides the methods I have already employed?
Thanks...
In case it helps... All of my other backed up DVDs do not have this issue.... all were backed up the same method using DVD shrink.
Results 1 to 11 of 11
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind...
That was your first mistake. DVDShrink is VERY out of date.
Yea......right.
Anyway...check the disc for surface dirt, try a different DVD drive, use better quality discs(next time) etc etc etc. -
Sounds like you've taken all the "fair-use" options available to safeguard your DVD's and the backup's failed ... seems like you're just unlucky in this case & will have to re-purchase new disks.
Try a different computer or at least a different DVD drive to rip the files from the back-up. I have several DVD-Rs and DVD+Rs that won't read completely using my main DVD drive, but will using my laptop's drive. It's a pretty good shot considering the back-up still plays properly on a standalone DVD player.
Try another drive - some are better readers than others. My best reader is an ancient 2X Panasonic.....not much for burning, but the old thing reads discs other drives can't.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Try DVD Decrypter with 'Ignore Read Errors' (on the I/O tab) ticked, or try ISO Puzzler, or ISO Buster?
DVD Decrypter with Ignore Read Errors is a good option. A little OT, but I've used ISO Buster to pull data from discs recorded in my DVD Recorder that wouldn't finalize and it's a good tool to have too.
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W. -
It's only a "mistake" to use DVDShrink IF it doesn't work. (If you tested your DVDShrink backup after you first made it and it worked, there was no "mistake" involved whatsoever. If you didn't, it may well have been a mistake.)
Lots of folks use it all the time, including yours truly, especially with RipIt4Me (also "VERY out of date").
Does it always work? No. And when it doesn't, it's very clear that it has failed. Then, on to DVDFab or others.
Does DVDShrink work FAR more times than it fails, even with some of the newer protection schemes (especially with RipIt4Me)? Yep.
An "oldie but goody" that still has a place in my backup tools.
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 14:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 15:55 -
I can't rip with DVD Shrink or DVD Decrypter
By Baldrick in forum DVD RippingReplies: 77Last Post: 10th Feb 2008, 12:46 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 22:45
