I'm trying to sync the Warehouse 13 podcasts to the DVDs. So far, it's a pain. You can barely hear the original audio playing in the background (although frankly it would be easier if it weren't there) so I have something to compare.
It sounds like the podcasts start several seconds before the DVD audio, and then go progressively further out of sync. I know how to correct for the former, but the latter is no so easy.
I know you can use Audacity to change the tempo of the audio, but I don't know how to calculate the "percent change" of the audio. If I know how far out of sync the audio is at two points, I should be able to calculate the rate the audio is going out of sync, I just can't figure out the formula.
Does anyone happen to know it? Guess and checking different percentages is taking forever, and it really isn't the best method.
I did a procedure here: http://www.mfbb.net/myvideoproblems/myvideoproblems-about25.html for re-syncing external audio with camcorder audio a while back using Audacity.
Not quite the same thing, but you could select the two reference points on both of your audio tracks, and apply the same procedure for creating a percentage correction figure.
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX general discussionReplies: 2Last Post: 2nd Aug 2009, 17:31 -
"Play All" caused audio out of sync (DVD Lab Studio, Half-D1)
By iryu in forum Authoring (DVD)Replies: 5Last Post: 21st May 2008, 01:52 -
"Unsupported audio rate in file" Message in Premiere Pro CS3
By JustinBaker in forum AudioReplies: 2Last Post: 23rd Mar 2008, 23:27
