Results 1 to 12 of 12
    Mar 2008
    Italy
    Hi everybody
    i have a mpg with teletext subtitle stream ( if i see it with vlc i can see subtitles )
    how can i extract this stream and convert in .srt ?
    this is videoredo report after cut (commercial breaks)
              File Size: 3986218896 ( 3.71 GB )      Program Duration: 03:12:48.06             File Type: TS Stream              Encoding: MPEG2       Video stream Id:  2602 (xA2A)   Encoding Dimensions:  544 x 576          Display Size:  544 x 576          Aspect Ratio: 4:3            Frame Rate:  25.00 FPS              Bit Rate:  10.000 Mbps            VBV_Buffer:  172 KB               Profile:  Main/Main           Progressive: Prog or Int                Chroma:  4:2:0          Audio Format:  Layer 2       Audio Stream Id:  2603 (xa2b)        Audio Bit Rate:  160 Kbps   Audio Sampling Rate:  48000 Hz     TS Mux Rate (bps): 2698368   Est. video bit rate:  2.493 (Mbps)            Subtitle 1: DVB Teletext, PID:0A2D, Lang:[ita], Page: 100            Subtitle 2: DVB Teletext, PID:0A2D, Lang:[ita], Page: 777
    this is dgindex that show teletext substream
    projectX not works ( i tried it some mounth ago ), and anyway now im on win7 and i tried already it, but is incompatible with win7...
    please help me
    thanks
    Mar 2008
    Italy
    extract empty srt
    are you sure that works with teletext subtitle stream?
  4. Banned
    Freedonia
    I think ccextractor only works on old style CC (Closed Caption) streams. I am not 100% sure about that, but I am more sure than not sure about it.
    Mar 2008
    Italy
    i tried projectx, works for mpg SD program but for ts HD h264 program not works... and vlc can show this stream (subs).... it's incredible... why not works with projectx.... i need a way to fix this problem
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Have you set the page number of the subs to extract in ProjectX? BTW ProjectX doesn't handle H264 streams it's designed for MPEG2TS only .
    ProjectX does work in Windows 7 both 32 and 64 bit editions.
    Mar 2008
    Italy
    hi net
    i founded a way to launch projectx on win7 ( http://www.maudja.net/2010/03/projectx-on-windows-7.html )
    and it works
    I thought it worked with ProjectX ts hd h264... so how can i extract and convert in .srt this ts hd h264?
    on google i can't find a solution...
  8. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Have you tried TSMuxeR, not sure if it will extract subs. Can't test it in Australia as our digital tv system (SD and HD) is mpeg2 + mpa and or ac3 audio with subs on page 801
    If you know or can speak German then the ProjectX forum might be a good starting point. There is a post here http://forum.dvbtechnics.info/showpost.php?p=34678&postcount=1 that might be asking at least half of your question?
    It would be good if the author of ProjectX could be encouraged to upgrade the program to include H264 as well as MPEG2.
    Mar 2008
    Italy
    tsmuxer can't show subtitles streams, only video and audio streams
    i try in projectx forum, but i think that the project of this program is dead, there isn't updates by some 6years
  10. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    You can get the latest version of ProjectX http://www.oozoon.de/main_en.html and the latest version is ProjectX 0.90.04.00.b32 from 31.10.2009 There is a a newish interface and the ability to save idx subs
    The German forum site last post is dated 11.09.2010 so far from dead.
    Mar 2008
    Italy
    thanks but not works anyway
    in attachment log from demux:
    lunedě 27 settembre 2010 15.41.48 CEST
    ProjectX 0.90.04.00.b32 (31.10.2009)
    -> working with collection 0
    -> save normal log file
    -> log 'packets out of sequence' / bit errors
    -> log 'missing startcodes'
    -> log 'PES header found in ES'
    -> log WSS
    -> log VPS
    -> log RDS
    -> log max. 500 warnings/errors
    -> write all video data
    -> write all other data
    -> patch c.d.flagged infos of pictures
    -> add sequence end code
    -> set resolution in SDE
    -> PVA: strictly specs. for audio streams
    -> VOB: determine diff. Cell timelines
    -> TS: ignore scrambled packets
    -> TS: enhanced search for open packets
    -> TS: join file segments (of Dreambox®)
    -> TS: generate PMT stream dependent
    -> get only enclosed PES/TS packets
    -> concatenate different recordings
    -> ensure 1st PES-packet start with video
    -> generate PCR/SCR from PTS
    -> write output files to: 'F:\Glee\1x16'
    -> main I/O-Buffersize in bytes 4096000 bytes
    FileSegments:
    * (0) F:\Glee\1x16\1x16.ts
    second. Files:
    +> Input File 0: 'F:\Glee\1x16\1x16.ts' (2.437.791.112 bytes)
    -> Filetype is TS (generic PES Container)
    -> demux
    -> Service ID 0x0001
    -> PMT 0x0100 refers to these usable streams:
    Video:
    PID: 0x0A1A(H.264)
    Audio:
    PID: 0x0A1B(AC-3){ita}[PD]
    Teletext:
    PID: 0x0A1D(ita_i100 ita_s777 )
    Subpict.:
    n/a
    !> PID 0x0000 (PAT) (0 #1) -> ignored
    !> PID 0x0100 (PMT) (188 #2) -> ignored
    ok> PID 0x0A1A has PES-ID 0xE0 (MPEG Video) (376 #3)
    ok> PID 0x0A1B has PES-ID 0xBD (private stream 1) (564 #4)
    !> dropping video data, GOP larger than 6MB
    --> PID 0x1FFF => stuffing packet -> ignored
    packs: 12892924 100% 2437791112
    ++> Mpg Video: PID 0x0A1A / PesID 0xE0 / SubID 0x00 :
    -> Video: fr-ct-1p-cg-og-dg -> 0-0-0-0-0-0
    ++> AC3/DTS Audio: PID 0x0A1B / PesID 0xBD / SubID 0x00 :
    -> check CRC of AC-3 / MPEG-Audio L1,2
    -> remove CRC in MPEG-Audio L1,2
    -> add frames
    -> Audio PTS: first packet 00:00:00.200, last packet 00:42:12.232
    -> adjusting audio at its own timeline
    -> src_audio: AC-3, CM, 3/2lfe(5.1), bsid 6, dn -25dB, cm -3.0dB, sm -3dB, 48000Hz, 384kbps @ 00:00:00.000
    -> src_audio: AC-3, CM, 2/0(2.0), bsid 6, dn -23dB, 48000Hz, 192kbps @ 00:00:00.192
    -> src_audio: AC-3, CM, 3/2lfe(5.1), bsid 6, dn -25dB, cm -3.0dB, sm -3dB, 48000Hz, 384kbps @ 00:00:00.864
    -> src_audio: AC-3, CM, 2/0(2.0), bsid 6, dn -23dB, 48000Hz, 192kbps @ 00:09:25.504
    -> src_audio: AC-3, CM, 3/2lfe(5.1), bsid 6, dn -25dB, cm -3.0dB, sm -3dB, 48000Hz, 384kbps @ 00:09:25.696
    !> CRC2 check failed @ 27141888
    !> missing syncword @ 27141890, @ 00:09:25.888
    !> found syncword @ 27143424
    -> src_audio: AC-3, CM, 2/0(2.0), bsid 6, dn -23dB, 48000Hz, 192kbps @ 00:30:47.424
    -> src_audio: AC-3, CM, 3/2lfe(5.1), bsid 6, dn -25dB, cm -3.0dB, sm -3dB, 48000Hz, 384kbps @ 00:30:47.616
    !> CRC2 check failed @ 88669440
    !> PTS without a frame (88669440/88669442)
    !> missing syncword @ 88669442, @ 00:30:47.776
    !> found syncword @ 88670976
    !> 1 frame(s) (32ms) inserted @ 00:30:47.808
    audio frames: wri-pre-skip-ins-add 79126-0-0-1-0 @ 00:42:12.032 done...
    ---> new File: 'F:\Glee\1x16\1x16.ac3'
    summary of created media files:
    Audio 00 (ac3): 79126 Frames 00:42:12.032 0-0-1-0 'F:\Glee\1x16\1x16.ac3'
    => 121.512.192 bytes written...
    -> we have 372 warnings/errors.
    Mar 2008
    Italy
    i try to demux teletext subtitle with projectx with uncutted .ts and works!
    but if i try to .ts cutted with videoredo, not works..
    so the problem is videoredo that change something, and projectx can't extract teletext subtitles
    i try to videoredo forum....
