Here is my motherboard: MB GIGABYTE|GA-880GA-UD3H R
I am going to be playing Final Fantasy XIV which is an MMO game that requires basically the highest processing a game has ever needed. It's going to have a TON of lag. Is the ethernet card build into the MOBO good enough? Or should I spend the money to go out and buy an additional PCI one that might impove my internet speed?
Thanks!
According to the spec it has "LAN: 1 x Realtek 8111D chip (10/100/1000 Mbit)"
http://www.hotelsvendor.com/computer/hardware/motherboard/gigabyte-ga-880ga-ud3h/
So there isn't anything faster than that.
Probably already 50 times faster than your incoming Internet connection, so look for your bottlenecks elsewhere. -
Ohhhhh So I'm good to go then? I'm a bit of a newbie when it comes to specs and things that.
Which ethernet card do I need?
By capman21 in forum ComputerReplies: 4Last Post: 10th Feb 2011, 01:11 -
Ethernet Video Card?
By liquid885 in forum Media Center PC / MediaCentersReplies: 8Last Post: 12th Jul 2010, 21:15 -
HP Ethernet Driver
By Sportster Freak in forum ComputerReplies: 14Last Post: 19th Mar 2009, 19:02 -
Ethernet Card Blown?
By Mitchum22 in forum ComputerReplies: 3Last Post: 24th Jun 2008, 14:30 -
Newly installed ethernet card into old PC w win98, no internet connection?
By Denvers Dawgs in forum ComputerReplies: 17Last Post: 10th Jan 2008, 10:55
