hi
i have avi file with streams video-cmp, audio-mp3 and would like to change aspect ratio PAR of file to see correct on my tv.
i tried to change par- aspect ratio with yamb, mpeg4modifier but nothing works.
is the any solution or do i do something wrong?
If the video codec doesn't support aspect ratio flags then you're out of luck. The AVI container doesn't really support aspect ratio flags. I never heard of CMP.
Can I change the pixel aspect ratio in an x264 AVI without reencoding?
By Calidore in forum Video ConversionReplies: 24Last Post: 16th May 2018, 17:24 -
Can you change Aspect Ratio in Avidemux without reencoding?
By tokintmash in forum EditingReplies: 3Last Post: 13th Aug 2009, 08:05 -
Change AVI aspect ratio?
By Solipsism in forum Newbie / General discussionsReplies: 25Last Post: 1st Mar 2009, 19:13 -
What best to change avi aspect ratio?
By drwho in forum Video ConversionReplies: 6Last Post: 17th Feb 2008, 04:30 -
change the Aspect ratio for an avi
By themaster1 in forum EditingReplies: 2Last Post: 27th Dec 2007, 12:27
