Hi all
I've now managed to join & convert my avchd clips to SD-DVD for sharing.
So that I can format my SDHC cards to use again I want to save the original HD clips on my laptop hard drive for the future when blu-ray players/recorders make an appearance in our home!
So, do I just need to save the MTS files?
Any advice greatly appreciated
Regards
Lily
	the mts is the audio and video the other files usually contain stuff like the timecode, but it's only useful if on a mem card in the cam. your choice, they're not big files you could save the entire file structure to your hard drive if you planned to write back to a mem card and play on the camera in the future.
 i would only save the mts files personally.--
	Yes the MTS files at a minimum. The rest won't add much to disk storage.
 Here is the AVCHD flash card memory structure. The *.MTS files are under /BDMV/STREAM
 http://en.wikipedia.org/wiki/AVCHDRecommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Wow, thanks for the quick replies!
 Great, I'm just starting to get my head around this file structure thing
 My intension is to (in the near future) author (if that's the right term?) these clips to a blu-ray disc with menu & a simple transition between each clip in continuous play.
 Regards
 Lily
  AVCHD (DVD) .ISO file, trying to extract original MKV from DVD imageBy SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55
  AVCHD Footage to SD (AVI for Premiere)By foochuck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 86Last Post: 12th Nov 2009, 14:39
  AVCHD footage to MovieBy provehighman in forum Video ConversionReplies: 5Last Post: 25th Jun 2009, 11:55
  FCP destroyed my original footage.By ettin in forum MacReplies: 7Last Post: 4th Jul 2008, 23:53
  AVCHD (DVD) .ISO file, trying to extract original MKV from DVD imageBy SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
