Results 1 to 1 of 1
    Sep 2010
    Germany
    Hi,
    im new in this forum. my english is not the best (im from europe) but i hope you can help me.
    i realised an avisynth-script to load an m2ts-file with VC1 video into virtual dub. i thought "yeah all fine" but now i see, that the color red shifted some pixels (approx 100, constant) up. if i play the original file with VLC there is no problem. if i play the avs with the media player, there is the same problem.
    what could i do to fix? i tried as codecs: ffdshow(DXVA) and MPCVideoDec. both same problem. Microsoft codec doesnt work.
    here my settings
ID:	3591Click image for larger version
    look over the heads, there are red areas. its the same picture if i use windows media player. if i use VLC media player, there is nothing linke this so i think its the codec or its a wrong avisynth-syntax.
    whats wrooong??
    as i said: i use win 7 x64
    source is m2ts (VC-1 i think)
    i used directshowsource("data.m2ts") on avisynth
    edit:
    i cant play the data.m2ts directly with media player. error : no codecs.
    same if i rename to data.ts.
