Ok so this is new thread for this https://forum.videohelp.com/threads/326247-Philips-5990-need-advice-on-what-HDD-to-get
I will be getting a WD 2TB HDD and I want to fomat it to fat32 and divide it (partition) into 2 equall halves. I will be doing this with swissnife and kind of need a step by step to follow so that both parts will be formatted to fat32.
Thanks,
What os are you running?If you are on vista or win7 you can do this through the administrative tools/disc management of the start menu.
Oh sorry about that. Yeah I'm on Windows XP. I already have swissnife installed. I have only used it once before and it was to format a smaller (older) hdd to fat32 and that wasn't too bad as I was only formating the whole thing to fat32 so that is why I'm asking for help.
As administrator; from the start menu, right click "my computer", left click "manage"
"Computer Manager" will launch
select "disk management"
muddle your way through repartioning the drive then use guiformat
http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm
or I guess Swiss army knife (which I don't know)
Alternatively, live boot a Linux distro like Puppy and use gparted. You won't loose any data that way. Warning takes ages.
PN
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 17:59 -
Partition HDD
By videobread in forum ComputerReplies: 3Last Post: 16th Dec 2011, 12:22 -
HDD recommendation 2tb or up and usb3.0
By lordhutt in forum ComputerReplies: 16Last Post: 21st Feb 2011, 20:26 -
Problem Formatting Ext HDD Fat32 Partition
By Shaky Jake in forum ComputerReplies: 6Last Post: 3rd Jan 2009, 17:27 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09
