Hi everyone and many thanks in advance. I am looking for help with removing the background noise in a sound file.
Can you please help? Anything I can do to remove the background noise in this file?
Again, many thanks in advance!
http://www.backstagenation.com/talkwithnoise.mp3
Not too likely.
You can try some filtering in maybe the freeware Audacity and see if you can get a slight improvement. But you will degrade the desired speech part of the audio. Try using a high pass and low pass filter. You may end up with 'telephone' like audio, though. The voices and the background are too close to each other in frequencies to be able to separate them efficiently.
Audacity has other filters you can experiment with.
And welcome to our forums.
noise or artifact/cube removal?
By darkdream787 in forum RestorationReplies: 11Last Post: 16th Jan 2012, 21:41 -
Noise removal in pinnacle studio 14
By RON36 in forum AudioReplies: 0Last Post: 16th Nov 2011, 07:49 -
Fix overdone noise removal
By John97 in forum AudioReplies: 1Last Post: 6th Feb 2011, 19:30 -
video noise removal
By snooze.saurabh in forum EditingReplies: 0Last Post: 1st Feb 2011, 11:36 -
weird sound after noise removal in audacity
By happydog500 in forum AudioReplies: 25Last Post: 3rd Oct 2008, 08:24
